570 ignition timing+workshop manual
sm570nut
Motorrad: sm570r gsxr750
Beitrag von sm570nut »
Hi can anyone tell me the ignition advance of a sm570 2002 at idle,ie degrees btdc,also anyone got a digital copy of the workshop manual,not the owners manual they wouldn't mind sharing :D cheers
* When you try to do something... nothing happens.
If you really want it to happen, you've got to do it.
Re: 570 ignition timing+workshop manual
http://docs.wavenetworks.us/manuals//20 ... Repair.pdf
whats your Problem with the ignition ? The timing is fix... nothing to set :ka: one "point" at the gearbox (12o´clock obove the Crank) and one at the grundplate of the Ignitioncoils... the Position of the Turningwheel is fix at the crank...
sm570nut
hi thanks,i have this manual,i'm looking for the workshop manual
sm570nut
dr.-hasenbein hat geschrieben:http://docs.wavenetworks.us/manuals//20 ... Repair.pdf
you replied to my previous post,i had to change my cases and the mark for the stator was different,5mm,i set it to this mark ,the bike runs great when it starts but is still difficult to start,many kicks and backfires,if i knew the degrees before tdc i could check it more accurately,i am worried about damaging the engine if its not set accurately,the carburration needs setting up but i need the timing accurate first
try this
http://docs.wavenetworks.us/manuals//20 ... 00-570.pdf
maybee you can find the rigth answer
sm570nut
dr.-hasenbein hat geschrieben:try this
great,there it is,page M17,i can't read the values though :kadw: thanks for sending me this cheers :prost:
sm570nut
Benjamin hat geschrieben:Bild
thanks,i have this,it shows valve timing not the ignition timing,ie the degrees before tdc it sparks at idle
the info is on page 324 section M in the manual but i can't read it
570 timing curve.jpg (9.66 KiB) 2637 mal betrachtet
Benjamin
Beitrag von Benjamin »
It´s not in the 2004 manual although it´s in the index. All I have is this:
sm570nut
thanks Benjamin,thats fantastic,been trying to find that info everywhere,i love this forum,so many people that know so many things :massa: .thanks again,kev :hva:
