570 ignition timing+workshop manual
Hi can anyone tell me the ignition advance of a sm570 2002 at idle,ie degrees btdc,also anyone got a digital copy of the workshop manual,not the owners manual they wouldn't mind sharing
cheers
* When you try to do something... nothing happens.
If you really want it to happen, you've got to do it.
- dr.-hasenbein
- "der Dino-Doctor"
- Motorrad: SM570R Doc. edit.
Re: 570 ignition timing+workshop manual
http://docs.wavenetworks.us/manuals//20 ... Repair.pdf
whats your Problem with the ignition ? The timing is fix... nothing to set
one "point" at the gearbox (12o´clock obove the Crank) and one at the grundplate of the Ignitioncoils... the Position of the Turningwheel is fix at the crank...
hi thanks,i have this manual,i'm looking for the workshop manual
Hi,dr.-hasenbein hat geschrieben:http://docs.wavenetworks.us/manuals//20 ... Repair.pdf
whats your Problem with the ignition ? The timing is fix... nothing to setone "point" at the gearbox (12o´clock obove the Crank) and one at the grundplate of the Ignitioncoils... the Position of the Turningwheel is fix at the crank...
you replied to my previous post,i had to change my cases and the mark for the stator was different,5mm,i set it to this mark ,the bike runs great when it starts but is still difficult to start,many kicks and backfires,if i knew the degrees before tdc i could check it more accurately,i am worried about damaging the engine if its not set accurately,the carburration needs setting up but i need the timing accurate first
- dr.-hasenbein
- "der Dino-Doctor"
try this
http://docs.wavenetworks.us/manuals//20 ... 00-570.pdf
maybee you can find the rigth answer
great,there it is,page M17,i can't read the values thoughdr.-hasenbein hat geschrieben:try this
thanks,i have this,it shows valve timing not the ignition timing,ie the degrees before tdc it sparks at idleBenjamin hat geschrieben:
the info is on page 324 section M in the manual but i can't read it
- 570 timing curve.jpg (9.66 KiB) 3322 mal betrachtet
It´s not in the 2004 manual although it´s in the index. All I have is this:
thanks Benjamin,thats fantastic,been trying to find that info everywhere,i love this forum,so many people that know so many things
.thanks again,kev
