elektr. Ölpump ??? I can`t see a elektr. think !!! The pump ist control by crankshaft. The left motor cover is from Bj.incl.92 with the little clutch. The Dealer Jola have bmade this System in the middle of the 90.
Jockel hat geschrieben:Hi,
Dear
Jockel
So this is an aftermarket system made by Jola.... or???
Thore Jensen
Dänemark
- Feel free to answer me in german, even though i write in english..
Years ago I saw also a Oil-Pump-System for the old 610-engine.
But I think its not woth the money. The 610-Engine (the old Engine, we call it "Dino") has Ball-Bearings. As long as theres no forced feed lubrication the Oilpumpe only spits the Oil to the Crankshaft.
So I think the this oilpump (and so oilpumps build in at mj. 1999 and above) are only good for one thing: A quiet conscience.
Huskyschrauber hat geschrieben:
Exactly ! And that's help's when you use the bike on the street. The main issue when you are riding with a TC engine (or an old TE engine) on a road bike is the valves overheating and breaking!!
Thore
Thore Jensen
Dänemark
Here are several Users (me included) which are riding the Dino on the street....I don't know any case where the valves or the valvetrain is making problems.
Huskyschrauber hat geschrieben:Here are several Users (me included) which are riding the Dino on the street....I don't know any case where the valves or the valvetrain is making problems.
Looong straight roads... Commuting outside citys.. allthough it can be prevented by letting of the throttle for a few seconds every 5 minutes, but still anoying..
Thore Jensen
Dänemark
If you know the Model-Year of the Bike we can help. you. If it is buidl in 1999 an up, there is the "normale" Dino-Oilpump, which only spits Oil to the Crankshaft. if it was Build 1998 an before, theres no Oilpump.
It's 2000/2001 Year. I think it's good, right? I'm sorry but I don't have more pictures. I'm going tommorow for this bike, where should I search oil pump line and can you show me how it looks like?
I thought the 1998 and less have "Spitting" Oil pump and 1999 and higher have "Pressure" Oil Pump
