100mm head gasket advice
Verfasst: 04.08.14 - 22:08
von sm570nut
Hi guys
away for a while and finally back to using my 570
I need to replace the head gasket on my 570,i have a 100mm bore with a wossner high comp piston,while i was searching to get a gasket i saw this
http://www.offroad-moto.de/enduro-mx-mo ... -te610.php
what would be if any the difference in using this aluminium gasket compared to the a conventional gasket,also is 1.5mm thick?
i previously used the athena 100mm p/no : S410220001004
any advice appreciated,thanks
Re: 100mm head gasket advice
Verfasst: 17.08.14 - 07:34
von Benjamin
Hi mate, not sure the aluminum item will seal accordingly. It doesn´t have any sealing lips around the water pipes. But then it´s just a guess. Why don´t you look out for a paper seal?
Verfasst: 17.08.14 - 19:26
von sm570nut
hi
the last one only lasted 50 miles but i think that was probably my fault as i previously had to take the head off after 5 minutes of running on a new gasket and i reused the gasket,knew you shouldn't but 60quid for five mins made me whince a bit and i took the chance,i didn't know wether the aluminium was more suited for use with the high comp piston,
Verfasst: 21.08.14 - 12:38
von Benjamin
haha yeah never reuse them, especially on the top and bottom end.
