Part It Out SMR-570 2002, 600ccm, Schlachtung
Verfasst: 02.09.13 - 19:35
Hello,
As I am ready to dig in the new one project finally decided to part out my ready project bike. I'll split it by the groups of the parts. I someone has an interest please let me know, I am open for negotiations.
[youtube]http://www.youtube.com/watch?v=clyYrYA1 ... e=youtu.be[/youtube]
Groups:
1. Engine kit = engine itself, carburettor + air filter with box, full cooling system, full ignition system, full exhaust system, controls for clutch, deco, throttle and shifting.
2. Suspension = front fork, fork guards, triple tree, shock.
3. Brake = front and rear callipers, front and rear master cylinders, guards, brake lines.
4. Wheels = Front and rear wheels with brake discs, rear sprocket and axles.
5. Chassis = Frame, sub frame, foot pegs, skid plate, swing arm, linkage, upper slider, lower slider, chain guard, kick stand.
6. Body kit = Tank covers, radiator covers, number plates, front and rear fenders, filter box cover, seat and tank with the accessories, fastening bolts and washers.
7. Electric = cable tree with accessories, control switches, vapor trail-tech with accessories, front light, rear light, turning signals, rear light mounting bracket.
I would like to collect at least more then half proposals regarding groups before to start it split.
The detailed history of the project as well as all components you could see more detailed here at http://www.supermotojunkie.com/showthre ... ng-project
1. Engine kit spec - 18 hours (like new)
Engine mods list:
606 cm3 at stock bore (98 mm)
Stroke (80.4 mm) & lightweight crank (-530 gr)
SKF high speed crankshaft bearings T-6
Wossner piston OEM size (98 mm)
Oversize stainless steel valves IN ø37 mm EX ø32.5 mm
Custom made titanium valve retainers
TC camshaft
Flow bench ported head
Lightened (-100 gr) 8!!!! plate FBF clutch basket
Rekluse Z-Start Pro clutch
Zupin clutch cover
FlowPro custom made sprocket cover
Cooling mods list:
Factory racing opposite cooling intake & pump
Samco Sport cooling lines with clamps
FlowPro custom radiator guards
Trailtech coolant temperature sensor
Ignition mods list:
Blue CDI 9500 rpm
Champion racing spark plug
Hot-Wire spark plug cable
Factory vented & armoured ignition cover
Samco-Sport cover vents lines
Intake specs:
Keihin FCR MX 41.5 mm
R&D power bowl 1
Floo-Commander (intake mouth 65 mm)
FlowPro custom made fuel atomization needle
FlowPro custom made flow accelerating plates (3+1)
FlowPro custom made high flow main jet
FlowPro custom made remote control and adjustment cables (idle speed + mixture + main air jet)
HTM-Racing air filter
FlowPro custom made fuel and coolant catch can
Polyurethane vent lines
Exhaust:
Akrapovič racing line full titanium exhaust system with accessories.
Exhaust is suitable for road legal use.
Controls:
Gunnar Gasser quick throttle control and cable
Zeta clutch control with deco leaver and cables
As spares:
OEM crankshaft with new one connecting rod
FBF high comp 13:1 piston kit low hours ~ 12
Spare gaskets for crank case half's, cylinder and valve covers as well as for right side cover and clutch cover.
Spare custom made sprocket cover
Price for whole kit of engine = 3400 EUR shipped within EU
2. Suspension spec:
Front - Ohlin's FG 007
Shortened travel (- 20 mm)
Springs for weight 85-90 kg wet
Zupin triple tree 193 mm wide, 25 mm offset
Fork guards with brake line clamp
Rear - Ohlins Factory shock
As spares - OEM Sachs rear shock, perfect condition
Suspension is fully serviced 6 running hours ago.
Shim's spec:
Shock Comp
3 38 0.15
1 36 0.15
1 34 0.15
1 22 0.11
1 34 0.20
1 32 0.25
1 30 0.25
1 28 0.25
1 26 0.25
1 23 0.25
1 20 0.25
Shock Reb
1 34 0.25
1 34/30 0.25/0.20
1 34 0.25
1 30 0.25
1 26 0.25
1 23 0.25
1 21 0.25
1 19 0.25
1 18 0.25
Fork Comp
1 22 0.15
1 22 0.20
1 18 0.15
1 16 0.20
1 14 0.25
1 12 0.25
B 10
Fork Reb
1 22 0.15
1 20 0.15
1 14 0.10
1 12 0.15
1 14 0.20
1 12 0.20
B 10
Price for whole kit of suspension = 900 EUR shipped within EU
3. Brake spec:
Front:
Braking supermoto calliper blue powder coated
Braking racing brake pads
Pro-Brake SS brake line
Magura 195 series radial master cylinder
Apico brake light hydraulic switch with long cable
Rear:
Brembo oem calliper blue powder coated
Pro-Brake SS brake line with clamps
Brembo oem rear master cylinder + leaver
FlowPro custom made rear master cylinder guard
Price for whole kit of brake = 350 EUR shipped within EU
4. Wheels spec:
Front:
Rim - Morrad Akkront 17" x 3.5"
Axle - ø 20 mm
Brake disc - wave floating ø 320 mm with speedo magnet
Flowpro custom made brake disc offset spacer
Rear:
Rim - Morrad Akkront 17" x 5.0"
Sprocket - Renthal 44z mounted.
FlowPro custom made sprocket offset (10 mm) spacer
Brake disc - wave ø 220 mm
Axle - ø 22 mm
FlowPro custom made axle clamps
As spares:
Renthal 41z sprocket
Renthal o-ring chain
Front offset sprockets 14; 15; 16 z
Front slick
Note - tyres are as they are = not in the good condition.
Price for whole kit of wheels = 500 EUR shipped within EU
5. Chassis:
Frame - Nox (with Zupin papers) street legal
FlowPro custom made skid plate
Roc-Stompa Pro Stompa series billet foot pegs
Sub frame - standard 570 aluminium
Swing arm - standard 570 mat black powder coated
Shock linkage - standard 570
Upper chain slider for offset sprockets
Bottom roller chain guide
As spare - oem aluminium skid plate
Price for whole kit of chassis = 450 EUR shipped within EU
6. Body:
Tank covers left and right
Cooler cover left and right
Number plates left and right
Filter box cover
Rear fender
Rear sub fender
Front fender oem 570 smr
Front fender oem sms 125
Seat + clip
Tank + fuel valves + Ikon billet cap
Body kit fastening bolts with billet washers
Price for whole kit of body = 450 EUR shipped within EU
7. Electric:
Cable tree flexi wrapped
Ignition key
Control switch
Turning signals rely
Horn
Head light assy of Yamaha WRF
LED tail light assy of Yamaha WRF
LED turning indicators Oxford Jupiter with resistors
Custom made taillight assy bracket
Trailtech Vapor computer with dashboard and mounting bracket.
Spare Vapor mounting brackets for different triple trees
Price for whole kit of electric = 260 EUR shipped within EU
Groups:
Engine mods list:
TC camshaft
Zupin clutch cover
Cooling mods list:
Ignition mods list:
Blue CDI 9500 rpm
Intake specs:
R&D power bowl 1
Exhaust:
Controls:
As spares:
2. Suspension spec:
Shim's spec:
Shock Comp
3 38 0.15
1 36 0.15
1 34 0.15
1 22 0.11
1 34 0.20
1 32 0.25
1 30 0.25
1 28 0.25
1 26 0.25
1 23 0.25
1 20 0.25
Shock Reb
1 34 0.25
1 34/30 0.25/0.20
1 34 0.25
1 30 0.25
1 26 0.25
1 23 0.25
1 21 0.25
1 19 0.25
1 18 0.25
Fork Comp
1 22 0.15
1 22 0.20
1 18 0.15
1 16 0.20
1 14 0.25
1 12 0.25
B 10
Fork Reb
1 22 0.15
1 20 0.15
1 14 0.10
1 12 0.15
1 14 0.20
1 12 0.20
B 10
3. Brake spec:
Front:
Rear:
4. Wheels spec:
Front:
Axle - ø 20 mm
Rear:
Axle - ø 22 mm
As spares:
Front slick
5. Chassis:
6. Body:
Filter box cover
Rear fender
Rear sub fender
Seat + clip
7. Electric:
Ignition key
Control switch
Horn
