Hallo from Athens!
I just found this forum and decided to sign in! I have a 1999 Te410e that is currently out of commission after it suffered con rod damage after almost 60.000Km. Instead of just fixing it, I have decided to modify it to make it a little bit stronger. So I got the crankshaft, con rod, cylinder, piston and a complete head off a Te610e and I am now almost ready to install them. I have a couple of questions that maybe somebody could answer.
1) I am looking for a Steuerkette for the Te610e. I am told that the one from the Te610 (without the 'e') does not fit. Does anybody know how many links it should have, so I can find one from DID, or another chain maker?
2) I am also looking to replace the clutch plates (Kupplungsscheibe). Does anybody know if I can use the plates from the Te610 (again without the 'e') model? If not, do you know who makes clutch plates for the 'e' model?
Thanks for your help.
Newbie in forum with questions!
- SchodderSchleuder
Re: Newbie in forum with questions!
hello hawk and greetings to athens! maybe you get your parts on this link: http://www.enduroversand.fidelitas.de/c ... xmatch=300 or you try zupin: http://www.zupin.de/katalog.html i hope you`ll find what you searching for ;)
