Hello Husky drivers :)
can anyone help me?
1. when I twist the throttle fast my Husky gives a loud "bang" from the exhausts and goes out for very short period. Otherwise it runs well - the spark plug are dark... is it wrong mixture ?
2. is it possible to remove the ignition key house- and what wirings have to be done?
3. Have anyone mounted a 2000 Lampmask on the older Huskyes? it seems that it cant because of the CDI - will it be possible to move it to another place ?
4. is it neccessary to clean the magnet on the left side of the cylinder- and is it only fixed with the 2 screws?
Thanks - and - Gute Fahrt
best regards
Jesper
Questions Husky TE/TC 610 1995
- altmaerker
- HVA-Urgestein
Re: Questions Husky TE/TC 610 1995
Hey Jesper,
before you take new oil into the engine you must clean the magnet on the left side under the cylinder. There are only 2 screws and behind the magnet can be a distance-gum. Attention, that gum can fall into the engine ;).
I`m sure that you can take the Lampmask from the 2000-models. And when it not realy passt you can take longer screws with distance-thinks.... say never "NO" ;)
Have you got a photo of this magnet and gum?
Best regards
Jesper
Best regards
Jesper
- altmaerker
- HVA-Urgestein
sorry i have no photo....., if you look behind the magnet you see the gum....
