OAT Antifreeze?
sm570nut
Motorrad: sm570r gsxr750
OAT Antifreeze?
Beitrag von sm570nut »
Hi All
Can anyone tell me if its ok to use OAT antifreeze in my 570 if its flushed and not mixed with glycol,thanks
Kann mir jemand sagen, wenn seine Ordnung, OAT Frostschutzmittel in meinem 570 Wenn gespült und nicht mit Glykol gemischt, Dank verwenden
sorry used translater :klopp:
* When you try to do something... nothing happens.
If you really want it to happen, you've got to do it.
sm570nut
Re: OAT Antifreeze?
Its not a trick question!!!
Has anyone used organic acid technology antifreeze in a 570????
Motorrad: TE 610 '95
Re: OAT Antifreeze?
Beitrag von Huskyschrauber »
I don't think that anyone is using this coolant.
Don't know if this coolant is known in Germany....
sm570nut
Re: OAT Antifreeze?
ok many thanks for the reply
Heretic
Motorrad: HQV TE 300, YZ 250
Re: OAT Antifreeze?
Beitrag von Heretic »
http://mgaguru.com/mgtech/cooling/cool_121.htm
clean your coolingsystem as good as possible. the OAT should be working fine in your engine. its made for magnesium and alloy-engines.
unklar
sm570nut
Re: OAT Antifreeze?
thanks,thats what i thought,just wanted to check with any other users on the forum
cheers
